There is a lot to read on here so sorry if I ask a question already answered. Will this block support the Svt intake manifold? And what is the questimated HP? And lastly( for now) Wanna build me one next year maybe?
Yes, if you use the bugzuki plates you could use the SVT manifold. Including the turbo my goal is to get at a minimum 500whp. As for the build, I don't know if I will have the time, but I doubt you want to spend the money. My engine alone will be over $6,000 I'm guessing, which does not include the turbo kit. That doesn't consider any of my time/labor either. However I'm interested as I haven't really totaled it all up (kinda don't want to know either), but here is a quick break down on the rough numbers that I can think of....
05 Escape 3L - $400
K1 connecting rods - $620
Diamond Racing Pistons -$686
Total Seal Rings - $213.20
balancing of rotating assembly - $220
cleaning block -$65
honing block - $120
checking deck heights - $25
check main housing bore - $10
Oil squirter machining in block - $300
bead blast cleaning of heads - $100
Port & Polish work on heads, rework of valves - ~$1300
Mountune Cams - $1700
Mountune Valve Springs - $400 (I bought them from a Noble owner, from Mountune ~$600)
Complete Engine gasket kit - $220
Celvite Main & Rod Bearings - $90
fuel injectors (1000cc) - $620
so from what I can think of above...
Grand Total of $7,289.20
You can buy an long block Noble engine from AER for probably about $4500, but that will not have the uprated cams, valve springs, ported heads and 1000cc injectors. So if you remove those from the list that puts my engine build at $3069.20 again which does not include labor. So I came out ahead as I am ending up with more then what a Noble has for an engine.
