impressive. how many miles since it was rebuilt?
Yes the Torco fluid was good stuff, too bad the owner, Evan Knoll was such a scammer.
http://blog.mlive.com/kzgazette/2008/08/financial_woes_mount_for_decat_2.html
Not sure if they are still in business or not.
That is pretty pricey, but in reality, looks to be worth it. If you look at the other recommended brands for tranny fluid, it isnt THAT far off from Ford Honey and Royal Purple.
Did you run a air-water cooler for the water returning to the supply tank though? I guess I'd be surprised if you did and still had high water temps. If you have a properly sized air-water cooler for the water that is cooling down your intake air then I would think you could maintain reasonable charge air temps.
No, you are a pissed off teen that is probably just jelous![]()
Not to mention he hasnt listed ANY reasons why those parts are bad, "they just are"!
Way to act like a pissed off teenager! Someone doesn't agree with me so Ii should get pissy and start throwing insults, yeah that'll work.
Where did this come from?? I'm confused...
Moving on....
if you are going to replace the synchros then you need to replace the bearings as well. the bearings have to be pressed off and almost always get destroyed in the process. Unless TH can sell you the kit for a better price I would recommend getting the rebuild kit from drivetrain.com.
http://www.drivetrain.com/parts_catalog/manual_transmission_overhaul_kits/ford_car.html
btw, if you have a press and a dial indicator this is something you can do yourself to save some money.
