Sick2000Svt
- Joined
- May 28, 2008
- Messages
- 127
there you go then you wouldnt have to go thru all the porting on the other heads.
Ugh... this is one of the grossest bits of misinformation on CEG. The heads are not junk. Do you know what Ford says to do if one/all cam caps are ruined/missing? Install new cam cap/s... not get new heads. They are all the same size for a given application.
You need to reinstall used caps in the same location that they were removed from because of any wear patterns that may develop between the cam & cap. A new cap on a used cam is just going to develop the same wear pattern that the old cap had - no harm there.
Now, I'm not sure about pricing of new caps, so it may be cheaper anyway to just get another set of used heads, but you don't need to replace a set of heads because of bad/missing cam caps.
This is what I'm disagreeing with. New cam caps have already been line-bored... that's how the journals are created in the first place. From my own experiences, (installing new 3L cam caps fresh out of the bag, into a 3L head), and according to the Ford engineers that I've dealt with, there is no need, and no good reason, to re-bore the cam journals. All cams, and cam journals, are factory-machined to the same spec with tight enough tolerances to allow new part replacement without additional machine work.If you were to get a set of new cam caps, you incur not only the cost of the new caps, but also machine-shop labor and materials since the new caps must be line-bored in order to match the heads.
Sorry, I wasn't trying to imply that. Nor am I questioning your decisions on your build. From what I've read of your posts on here & Neco, I'm sure you've got it under control and this puppy will be up and running well in no time.I never suggested that the "only" thing to do was to throw the heads out
Sorry, I wasn't trying to imply that. Nor am I questioning your decisions on your build. From what I've read of your posts on here & Neco, I'm sure you're well in control and this puppy will be up and running well in no time.![]()
Arg! once my refund from blackcoog stops "pending" i will send some money asap to help ya out! Keep my motor nice and sealed for meh though :laugh:
Edit: As of this morin its still pending... 5 days now...
Yeah, Paypal sucks. I don't know why refunds take so darn long.
Paypal randomly selects transfers to delay which is what happened in this case because there was money in the account to cover the transfer. Even if there wasn't money in the account to cover the transfer usually bank transfers for payments is instant as long as you have a credit card associated with the account.
Sorry Chris i didnt mean for it to be personal, if it was. Didnt in no way intend it seeming as if i thought you didnt have the money for the refund.:shrug:
Hopefully Lilce98's car is up and running soon.
I saw this picture in my phone and it made me laugh :laugh:
