I have a clearance issue with the old oil cooler/ water pump hose. I deleted the svt cooler when i first did my swap, it seems the routing isnt going to work anymore, does anyone have a pic of a non svt's setup?
Can you turn the hose elbow 90º and route the heater line up under the water pump and throttle body? Probably best to replace the molded heater hose with a length of regular hose from the auto parts store. I also deleted my oil/water-cooler/heater and it greatly simplified the heater hose routing. I got rid of most of the molded heater hose, still had to use hose elbows on the heater core nipples at the firewall.
If that won't give you the clearance to the jack shaft, you may have to pull the water pump housing, cut off the hose nipple, tap the housing for 1/2" pipe thread and install one of these:
From here, about 3/4's down the page:
http://www.anplumbing.com/Adapters/Aluminum-14.html
Get used to hitting roadblocks with this sort of thing. I've been putting aftermarket parts on car for over 30 years now, and it's rare when I don't have to fit-file-cuss or re-engineer something.
