For oil cooling, you will have to either do a remote oil filter setup or what i eventually did and put a sandwich block on the motor and run pipes round to an air cooled rad.
This is one of the fitment issues i tried to talk to Marty at MSDS about .
The non SVT water route goes from the water pump outlet ( that went to the oil cooler) straight to the heater rad. I used a piece of water hose that had u bend on the end and joined it (engine side behind the vortech transmission mounting plate, where there is a water pipe join already) to the heater pipe. You might be able to rotate that pipe you have and route it engine side of the jackshaft. You may need to trim a little length off but what you have there should work once you've modified it.
The water pump hose outlet ... is it fouling the black block on the jackshaft ?
If so. you need to file flat the rounded section between the 2 bolts on the black block that fouls the pump, so that it clears the water pump outlet. Even after filing a flat, it is still a bit of a pain to locate the jackshaft and tighten the bolts . G.
