man what a mess last night turned into. So after all the work I get done I decided to take a cruise to the pike to see whats going on down there.
so on the way down the instrument cluster cuts out a few times. annoying yes but I tunr the turbo timer off, drop it into neutral and restart the engine. this makes the gauges work again. Well getting off the highway on to RT15 some bikers deside I/m not going fast enough so they split me (both had riders with them) and go around me as the lane narrows down between highways. so I kick it down and gear and tear off after then for a few seconds. That is when everything went to hell. the whole car shut off. complete lost power. so I coast off the next exit and then the power comes back on. I was able to start the car but the gauges didn't work again so I kill it again and try to restart it with no luck. So I was able to coast off the road into a parking lot at least. well here is where more fun begins. The start isn't working. I check the battery, throw the jump pack on it, jump the starter to see it it works and nothing. So after talking with Roger and Greg I was going to try to pop start the car. But at that time I also was trying to mkae sure the starter still worker. So I took the solenoid power wire and jumped it to the distribution block. THe starter worked so I turned the key on and started the car this way. Once I got on level ground I tried the starter normally and it was fine.
So somehting odd happened and the battery disconnected. then the alarm or some wiring between the igntition and the starter, or the alarm was acting up.
Funny on the way home the car ran fine. gauges cut out one and there where no issues. In fact the voltage was the best I had seen it all day ....
but luckly I got home and I am goign to go look at it quickly.
