Beans
Addicted CEG'er
How'd the rest of the insides turn out?
You're going to need a variety of shims, sockets, adapters etc to press it all back together. As with any other thing that gets pressed together/apart it's all about finding the right adapters to drive the parts together straight while properly supporting them. The how-to's on the mustang sites are actually pretty good, I'd start by reading through those a few times. This isn't an overly difficult task if you're fairly mechanically inclined but is definitely something you need to take your time and do it right.
You probably could do it that way but I wouldn't. You run the risk of the gears binding when assembling it. The coupler shouldn't go on/off very hard so it's really a non-issue. Once I get this one off and cleaned up I'm sure it'll be no different.
I was trying to think of a way of pressing the parts back on before assembly of the two halves. to avoid crushing the casing and/ or the thrust washers. I didn't fancy stressing the two threads to re-assemble, in case something went wrong. Pressing before assembly, using the other end of the shaft they are being pressed onto seemed favorite.... i guess not.
is there a vid online of someone stripping and rebuilding a unit ?
I did look; the closest i got was some guy in Canada thumping a head unit and a hammer on his bench encouraging you to send yours' along. He got slated by the Mustang community after someones' head unit got futzed ....G.
I'm capable, i installed my Torsen, camshafts twice etc. but as you said, i'm just being cautious after waiting 2 years for a vortech kit to come up for sale.As I've said before, I know you're trying to figure it all out ahead of time but I think you'll find once you start disassembling it that it is easier than you think. If you're not comfortable with it find a friend that has rebuilt a turbo or something along those lines to help you with it.
yeah, great to see you guys coming thru for him .....G.BTW, it appears that Beans just hit the Vortech parts jackpot. Nice!![]()
