svtfixer
as far as the impeller upgrade, its tempting but i doubt its a massive gain or any gain.
not worth it for me. my impeller aint broke. .
i dont think i had belt slip issues with the smaller pulleys. i did play with a bigger idler and spacing on the idlers to make up for the surface area loss.
so if one was already running the smallest pulley, short of custom making a pulley this is the only option out there for more power?
I would get a whole new unit all together, personally. Find a g trim v9. It's 600$ for impeller & machining + shipping. stuffing a larger impeller into the same unit. You won't get as much as a actual g trim blower. Smaller inlet and outlet then a real g trim. ••••, you can probably find a g trim for 600$
Assuming it fits...
Not sure if it's larger honestly, i assuming with the housing getting machined it would be. I wouldn't bother doing business with that supercharger rebuild place anyway, guy is a prick especially after giving him as much money as i did.
the 2.78 was 3 sizes down from the stock 3.33 which was at 6 psi and each size down is 1-2 psi at 10-20 hp.
