blu_fuz
New Member Classroom vulture
holding for steve @ tousley ford...........
still holding..............
'90s hits :yay:...............
BINGO!
Steve is the man - so are you, thanks so much!
My parts people always told me that I couldn't get that fitting. After reading KyleQ's post, I check for myself meandering through the parts software app... and find the fittings. And they're cheap as hell too. Such a conflict of interest to pay someone commission for quoting/getting me parts.Where can I get that hex nut and 0-rings from?
If I hadn't grown used to using the parts software due to the laziness/incompentence of the parts guys I work with, I would probably start calling him too!Steve is a parts CD - he finds what you need.... sometimes off the top of his head.
Mine WAS showing the fitting at the pump, just not differentiating between the two numbers.these fittings are only called out down by the rack in the parts database and not up by the PS pump.
You can borrow mine... just come get it. :blackeye: :laugh:anyone have a dremem?
no, seriously
Hey Kyle - did you try heat? I wonder if torching that puppy could expand it enough to be able to pop it off the line... onder:
So the answer to the question I posed is "no, you didn't try heat" - gotcha. You could have saved yourself a lot of typing on that one. But at least now I know where to send people that might actually be in need of advice for beginners... or are just retarded.
It's cool... and I feel you on being slow at work. I'm looking for a part-time job to help pay the bills. :help:Sorry - it is really slow at work and it sounded humerus at the time.
Fitting was supposed to come yesterday with the shipment to Ford..... It wasn't in the container :blackeye:
I went to NAPA, and they have the entire pressure side of the hose for $29!
I thought I might just replace it then.... no freakin way - subrame bolts kicked my ass and I can't reach the lower fitting on the steering rack to even loosen the connection. Sooooo, I wrapped a plastic bag around the connection on top and spun electrical tape around it for now to keep it from dripping on the belt :blackeye:..... still need a dremel too :blackeye:
I did exactly what was posted earlier for cutting the nut. It worked perfectly. No leaks - thank you
YAY... Same problem here... I've been tracing this leak for days. Only squirts when steering is used. I was like WTF why do I have traces of fluid on my sub frame and fluid disappearing from the reservoir. The problem is that it takes about 3 days to go low before I notice the pump whine. Come to think of it I did take this thing apart before when I was troubleshooting the noise.
Stupid Canadian dealers did not know what I was talking about either until I gave them the part numbers from here. Picking up a couple today.
I love CEG, collective thinking works!!!
