99Mystique ATX
There is not enough room to run a wider bearing (or bearings) on the jackshaft without modifying several things...
The folks at Vortech are pretty smart, and have been dealing with high speed bearings for many years, so I suspect they made engineering, compromised.
considering the shielded and the rubber sealed bearings are exactly the same, one is rated 14k the other 9k... it occured to me that it wasn't just the rubber seal failiure that could be killing the bearings.i figure there may be a unit of the same dimensions just with the new technology. but youre saying that to handle the rpms its going to be a different dimension? wider?
at least its relevant. i have my jackshaft out. what info were you looking for on it?
Based on what I've seen, the inside bearing (s/c side) is usually in the worst condition.
ideally wider bearings would be best, if it was just 3mm to be taken off the shaft.If you turned the shaft down (section separating the outer and inner bearings) so you could run a wider bearing on the inside I think you might be able to fit a wider bearing in there. However, I'd make sure the jackshaft went to a very good machinist who knew exactly what you wanted done. It wouldn't take much and you'd be out of a jackshaft and stuck with an expensive paperweight.
do you think being in the center of the shaft where there is most flex, may be a contributing factor ? Maybe a bracket could be made to brace the center.
One question pops up..... if you machine your shaft, do you think you can still retro fit the stock 15mm wide bearings ?
BTW; how did beans' jackshaft look for runout ? ...G.
i only asked because when you look at failed bearings, you can sometimes tell what has caused the failiure. Since you have the experience, i thought you might have some insight to how they failed. I haven't seen one of those failed bearings up close.Would it help? Sure, but it wouldn't be worth nearly the time, cost and effort to do it. I understand trying to improve the design but there comes a point where it's just not worth it. If you need a car you can reliably drive a 25k+ per year throwing a Vortech on it isn't the way to go. It's great for a toy or something you can work on but IMO that's about it..
Like I said before, if you really want to modify it I'd run at 6205DU on the pulley side and then machine the shaft and then possibly run a wider bearing on the s/c side. I'd have to run some calculations to see what makes sense but that could work.
These Things aren't cheap let alone available to play around with
Again. 30k is unreasonable maintenance on a car that didn't come with forced induction from the factory? Don't think so.
If something fit direct, it would be worth a upgrade. Too much work otherwise. Seems like that doesn't exist, therefore beating a dead horse!!!!!!!!
I think you guys are being over zealous with the idea.
